Just wanted to see if anyone else has had this. 06 R/T. If I accelerate easy, no problem. The harder I accelerate the worse the vibration is, but only between 20 and 30 MPH. Below 20 or above 30 is just fine.
Thanks in advance!
This could be 1 of many or many of many things depending on where you "feel" the vibration from - U-joints - Isolators (there is a set of fiber/rubber "disks" @ each end of the driveline) - frontend/rearend (ring and pinion play) for my 05 it was a combo of the front diff (typical 05 issue) and the rear diff
With your foot on the brake go from park to drive and drive to reverse do you hear/ feel a "thunk"?
Ended up being the center carrier on the driveshaft. The bearing was fine, the rubber in the mount was gone.
