1 - 1 of 1 Posts
The word WPS stands for “Wi-Fi Protected Setup” is a safe, advanced and secured mode for making the connection between a router and wireless printers and other devices. The person has to find WPS Pin on their HP printer to establish a connection between the accessible devices. The wireless technology that is used in the HP printer allows the person to print the documents from any corner of their home and also at any moment of time. The WPS PIN Code will be used for connecting your wireless HP Printer to your personal device and set the printer up either through a wired network or through your wireless router and starts printing the documents freely. In case you are a non-tech person and don’t know from where the PIN code will be found, obtain reliable HP Support Assistance from the well-qualified techies. You will meet that person only when you give a ring.
If a person installs an HP printer driver on their computer and the printer is asking for “WPS Pin” for making a wireless connection, then one has to read out this blog post carefully and follow the guidelines mentioned here. Getting the WPS PIN on HP printer is quite tough for almost all non-tech users. Therefore, you may also come across some troubles while setting up your HP printer to the network connection. Don’t panic we are here to help you.
Turn on the HP Printer
Open the control panel of your HP printer.
Head off to the ‘Settings’ option by pressing the Wireless button.
Tap on the Wi-Fi Protected Setup.
Follow the prompts appearing on the screen carefully.
Tap on the "PIN" option once a PIN appears on the screen of your computer.
Once you tap on it, you will come across a WPS PIN.
So, you can see the WPS Pin on your HP printer and now you can use it for establishing the connection.
By using the WPS Pin and WPS button, you will be able to connect to your device in a trouble-free manner. In case of difficulties you come across while connecting to the wireless network, you should approach our tech geek for help regarding the same and get the proper information about WPS Pin.
1 - 1 of 1 Posts
