21 - 23 of 23 Posts
Included:map sensor,fuel injectors,blow off valve, expansion tank.boost gauge,spark plugs,vacuum block,air filter,serpentine belt,idler pulley. clamps,hoses fittings.Kit is preassembled into five main components.Supercharger,intake assembly,discharge assembly,vacuum block,expansion, tank relocation.
Base tune included.
Not included flash tuner,water methanol injection kit,air fuel gauge.
All HP gains are documented with dyno graphs.
The units are rebuilt with all new internal gears,high speed ceramic bearings
If everything listed above is included, then the price shown on the website is a very good deal.
Have you had any known/reoccurring issues with the "PowerDyne" head units?
The powerdyne units were notorious for chewing up internal belts.There is a coating on the internal gears that will wear over time,this creates heat on the belt and will fail.This is the main reason for installing new gears.
If you stay within the build parameters the unit will last a long time.
I have 20000 miles on my stage 3 and I go to the track when i can and I have never had a head unit issues.
The advancement in bearings and belts have given new life to the powerdyne.
If you want to assemble your own kit the mounting hardware is available along with the build sheet and install video.
I am currently running the stage 3 with lightweight input gear,upgraded impeller shaft,upgraded belt guides,gates GT Kevlar internal belt,bearing cooling fan and ceramic bearings.
With a 2.75" pulley I am currently @ 11lbs of boost making 340 RWHP.My best 1/4 mi time of 13.8 @ 101mph
Currently this kit is installed on the worlds fastest 3.5 V6.
2007 Magnum SXT base, Bilstien shocks, struts, cold air intake, Jet Stage 2 chip.
This one is definitely worth looking into as I mentioned above. You should do some research on the quality of "PowerDyne" head units and inquire about what is exactly included in the kit. I will make up a list for your reference.
Feel free to ask anything else as it comes up.
Hello all, new to the forum, and I know this is YEARS late asking. I picked up my 07 Magnum SXT a few years back, and am at the point of wanting to do a few things to it., one being a supercharger, but being 2022 Im finding there are no actual kits anymore, Powerdyne, Tidalwave and whiplash are no longer around, but Im sure I can still put something together, the main issue Im having is all the mounting hardware plates and brackets. I have sent emails to the companies that are still in business about any left over parts, I got pretty much the same answer from all. "we dont do that engine anymore".
any help would be greatly appreciated.
thanks ahead of time !
21 - 23 of 23 Posts
