1 - 8 of 8 Posts
I need to know if these will squeeze on RWD mag.
Specs:
Size - Front 22 x 9.0 / Rear 22 x 10.5
Bolt Pattern - 5 x 115
Offset - Front +18 / Rear +21
Yep, those should work.
Thanks cuz, aye wit the 10.5 should i run a 275 tire or just run 265s all around?
On my 06 Magnum SRT I have the same bolt pattern, about the same offset, but have 9.5" on front and 10.5" on the back. I run 265x35x22s on front and 295x40x22s on the rear. No problems with mine.
The 265 tire will run on the 9.5" wheel. You can go 285 or 295 on the 10.5" wheel. The rear wider tire should be a 30 series instead of 35 series like the front. A 30 series will keep the height of the tire sidewall the same. Example : 265/35/22 - front, 295/30/22 - rear
Fireman, thats the exact tire combo I had on my R/T Magnum before I bought new tires. Mine's bagged and they tucked just fine (with rolling the inner fenders).
Thanks for the input peeps. Dropped tha cash on them, now the WAIT............................. living abroad SUCKs @#$%
1 - 8 of 8 Posts
