I have a set of 20's from my s10 that would look awesome on my Magnum. I don't know how you figure in all the fitments, but is there a spacer out there that would allow me to run these rims? The s10 wheels are Offset 0-15mm Hub bore 70.3 mm Bolt pattern 5x120.7 (5 x 4.75). Help me out guys.
If the wheels you have are a 15mm offset, you should get the thinnest you can get. I think they have 20mm. You want to use something that wont have you sticking out too far. I don't know how strong or safe they are. If I were you, I'd look around and see I'd you can find any info about these and their use. Google search. I found those adapters in 30 secs you should be able to find other info too.
