Thats pretty much how you do it. It is held in with snaps if you pry the edge of the seam closest to you with a plastic pry tool (so you dont wreck your dash or your speaker cover it will just pop up. Then you can take the speaker out and install the new one.
Just make sure you use something that is not going to scratch or dent your plastic dash. A good tip is insert a flat putty knife and then your pry tool and pry towards your putty knife so you dont mark your dash up. or use a plastic pry tool if you can find one.
Major Mag Nut
Speaker Removal
It's pretty simple, but here it is from the manual.
To get the door panel off is a completely different story for the door speaker.
