Why do i need an alignment when I replace the shocks and struts?
It isnt a macpherson strut, how will the alignment be through out of whack by replacing them?
As long as all the suspension components are in good shape and the ride height doesn't change, you probably don't need an alignment.
Fireman, Thank you.
JL KA, since the strut only suspends the car and doesnt act as an upper control arm, how will the alignment be effected?
I had my rear alignment checked after I dropped the cradle for my sway bar, but you won't be doin that if you're only replacin the shocks. If you start replacin tie rods/ends or tension struts on the front end, you'll definitely have to get an alignment to prevent destroying your tires. When I replaced the front struts only, I didn't have an alignment done. My steering still felt straight at that point, no pulling or drifting.
