1 - 2 of 11 Posts
Delta
· Registered
Discussion starter · #1 ·
whats up, just installed my new rotors from Brake Performance.com, the dimpled and slotted ones. and i have a horrible squeel as well as (i think the caliper clip) a grinding sound. is it a must to replace the clips? also i just got the rear rotors from the same site and everything. all ceramic pads. now will the ceramic pads cause this since the weather is still pretty cold? should i go pick up some semi metallic? anybody else have this problem?
Discussion starter · #8 · (Edited)
i've done the "bed in" stuff a few times. i'll get some brake quiet.
UPDATE: went to the auto store and got the "Brake kit" that has the caliper clips and due to some problems i was only able to get the left side down but the squeeks and squels stoped! i also got some of that quite brake gunk stuff... i think it was called Squeal Medic. but now time to do the other side and install the rear rotors.
1 - 2 of 11 Posts
