New AWD Coilovers from BCRacing
In the summer of 2009, we came across this thread- Official AWD Coilover Thread - LX Forums Modern Mopar Muscle about coilovers for the AWD LX platform. We jumped on it, because at the time of this writing, finding any performance suspension parts for the AWD cars is tough. KW makes coilovers for the AWD platform, but they come at a high price.
Fast forward to November 2009 and their arrival. We're going to go over the initial install and fitment of them for anyone wanting to tackle this job themselves.
The coilovers are made by BCRacing and supplied by CircuitMotorsports.net. The actual coilover kit we are installing is the very first prototype kit made. This install serves as the test install for the manufacturer.
With that, lets go into the install.
Jack up your car and remove your wheel. Secure the jackstands and ensure you are working safely.
(Above) Start by removing the outer tierod. Remove the bolt and use a puller to push it out. Don't tap the top with a hammer, you will damage the threads. Remove either the top or bottom of the stabilizer link. We remove the top. You'll also probably need a 3-jaw puller to push it out
Now we need to continue by removing the lower shock assembly. Start by removing this nut and the bolt that tightens down around the strut. Next, remove the bottom bolt from the lower shock assembly and the lower control arm.
With the outer tierod out of it's way, push the bolt out. You'll notice that the shaft is knurled just below the head. You can't twist it out, it has to be pushed out. Once the above steps are completed, you can pull down on the lower shock assembly fork and remove it from the car.
The strut is now just being held in place by the three bolts up top on the strut tower. Have someone hold the shock to prevent it from falling out, then remove the three bolts. Your strut will now come out the bottom. Installation of the new strut is the reverse of removing it. Here is a photo of it installed (below).
Don't tap on threads with a hammer to push these balljoints out. Use a puller. You can rent them for free at most quality auto parts stores.
