21 - 40 of 123 Posts
OK, I tinted my Factor One LED's, but I left the reflectors exposed so they are still semi-legal.
I did two coats of tint on everything but the turn and backup light, which only got one coat, and several coats of clear. It was so hot the clear was drying as I was applying it, so shoot and repeat...
Hey, about how long would you say this took you to do? I just bought everything you have listed on here and I am gonna use your very detailed instructions to do this possibly this weekend and just wanted to know is there anything I should look out for? Thanks!
Looks good and hope mine dont get screwed up!
-Chris
When clear coating how long should I wait from the point I spray the clear to when I sand it? Wait until dry of corse but any prefrence?
Also I am taping off the blinker and reverse light parts (like steves) and want to know... After I spray the coats of VHT do I take the tape off then wet sand and clear the whole light or do I leave the parts that are taped off alone?
Last thing... When buffing it will any orbital buffer work? Any details on this process? This is the first time using a orbital buffer so just want to know.
Thanks!
I am in the process of doing this fun task now and I just sprayed my first coat (going to do two) and noticed I have a little bit of running on one light on the side. If I wet sand them after they dry will that take that out? Or what should I do? Thanks.
I fixed the running problem by wetsanding the lights back down to the lenses, but now there is a slight problem with the clear coat. I wetsanded with 1000 grit then did 2 coats of VHT and 4 coats of clear and now the lights are partialy clear, (wetsanding with 2000 grit paper between each coat). They have this weird texture to them and would like to know if anybody else had this problem and/or how to fix it. The lenses are smooth to the touch but like I said there is this kind of specked texture to them. They are both the same way too. I was told to wetsand them again with 2000 grit and then polish them but everytime I sand them they get really "cloudy". Is this right? Any and all help is well appreciated!
What kind of Clear Coat did you use? is it a lacquer finish? i would just give them one more hit of the clear coat and Don't wet sand them if you have no more runs and just polish them with a buffer. I today just decided to tint mine more and i was faced with a dilemma, I wet sanded the clear coat and then applied more VHT and all of a sudden, the coat turned all spiderwebby, i guess the clear coat must of not been a Lacquer or somethin of the sort, cause now i gotta let them dry and sand out that coat and try again. Sux cause i'm almost out of the VHT
I used the same clear steve used in the start of this thread (the link in the beginning). They look good to me other than the little specks. Anything special I need to use/know with the buffer? (never used one)
ok I just got my vht....I got some clear coat...the clear coat is "dupli-color truck, van, & suv clear top coat" is that what i need? and at the risk of sounding dumb...what is/ how do you wet sand?
