61 - 80 of 123 Posts
I know this is an old post, but I just ordered my VHT Tint and I want to make sure I understand everything. The part about polishing is what I'm not sure about. I don't have a buffer, so what would you all recommend to use doing it by hand? Thanks in advance for your help! :cool5:
After you clear coat, (4 coats) give your lights 2 days to dry. Use 2000 grit wet/dry sand paper. (keep it wet) The better you sand it, the easier the hand polishing will be. Be careful not to sand through the clear coat. That's why I say do 4 coats. The hand polishing will take longer than with a hand buffer but it can be done.
FYI - 5" or 6" orbital polishers can be bought at most any auto parts store for $20.00 - $30.00
Thanks, I never looked at orbital polishers at the store, had no idea they were so cheap!
Hand polishing is possible yes, just make sure to give paint/clear time to cure or you will hate life
Do I use polishing compound or what? I never messed with the len's before other than using the polishing compound. Sorry to sound so inexperienced.
Treat it the same way you'd treat your paint.
Just came across this thread. Definitely a mod we can do. Anyone out there have a Magnesium Pearl with this done? If so, can you post pics and how many coats of nite-shades did you use? TIA...
Is everyone replacing the bulbs in the stock tails? Should I throw in some LED bulbs, or is it not necessary. Also for those painting over the reverse/signal lights. How bright are they in the day time. Can you still tell if someone is backing up or turning?
I am doing this mod as i type, AND i am doing some nice eyelids for the headlights as well with the VHT niteshades, i will post my own thread with some pics prob. in the early AM
nah man, jus a reg. hand buffer with some good polish, or a micro-fiber towel and polish and get to buffing
