Wire Routing
WARNING: When routing wires into vehicle, it is extremely important to not let wires get pinched or crushed at any time. Avoid window track and sharp edges at all times. Not doing so may cause circuit shortage problems in the long run. TIP: A gopher rod (wire) maybe use to assist in the wire routing processes.
1) Find the rubber boot located between the door frame and vehicle frame. Using your fingers, push in and pull out door frame end of the rubber boot. Pull back the protective sheet, route the wires alongside original wire harnesses, into the hole, and out the access hole vacated by the removal of the rubber boot. Carefully pull to remove any slack in the wiring.
2) Using the slotted screw driver, push and pry the rubber boot connector off of the vehicle frame side.
3) Route the wires thru the rubber boot.
4) Unsnap and remove the plastic trim and kick panel.
5) Route the wires thru the access hole into the vehicle. Replace the rubber boot back into position. Pull on the wiring, removing any slack in it.
6) Locate the grounding bolt within the kick panel. Cut and split the red and black wires. Route the black wire to the grounding bolt location. Cut the black wire to length, making sure enough slack is left for splicing. Splice the black wire and attach it to one of the supplied grounding rings. Attach the grounding ring to the grounding bolt on the vehicle frame.
** Repeat all of the previous steps to replace the factory mirror on
the passenger side door.
TURN ONLY
The wiring location for the TURN ONLY is located in the front control module, in the engine bay. Extra wire will be needed to go from inside the vehicle, through passenger side firewall opening/grommet and then to the wire loom. Locate the WHITE w/ LIGHT GREEN stripe wire within the wire loom. Turn the ignition key so that electrical power is on and activate the driver side turn indicator. Probe the wire with the wire tester to verify that flashing turn
directional power is present. Label that wire as ‘driver side indicator’. Find the WHITE w/TAN stripe wire within the wire loom. Turn the ignition key to on. Activate the passenger side turn indicator. Probe the wire with the wire tester to verify that flashing turn directional power is present. Label that wire as ‘passenger side indicator’.
